МEGANE RS CUP ''20
Alfa Romeo 156 SW 1.9 JTD
made spacers for the fuel injectors.
640кб..?????
ALFA ROMEO 156 2.4 20V JTDM sportwagon ALFA ROMEO 155 Q4 300+++Ps.
Alfa Romeo 145 3.0V6
Alfa Romeo 33 1.7 16V 4x4 Аlfa spider 3.0 V6
Hello Guys,
I will order also such LSD Diff for 2.0 16V, if it is possible to be deliverd to BG
Whrn will be the first samples?
Alfa 146 1.6 TS ---> 2.0 TS Remapped by Oem
FIAT TIPO 1.6 DOHC
A long time did not write anything)
Tell me, old-timers of the forum, it is worth buying tvinspark 8v AR155? I highly recommend it to buy, because this engine is very good billet for tuning. What do you think?
exhaust manifold
Looks really nice. Like a PRO!
I'm following this Thread with huge interest.
AR 145 2.0 16v Turbo 300+ whp powered by ICIDesign
AR 155 2.0 16v SUPER
Toyota Corolla 2014 S Premium
Moskvich 2140
I think the limit of the engine sleeves (the 8V TS unlike the 16V is a wet sleeve engine) was around 300hp. If you are not pushing for higher numbers it will do the job. Other than that it is a very good engine. There are few people in the forum with first hand expirience with 8V turbo convertion. Maybe they can give you more detailed info.
Компромис между науката и религията: Човек е произлязъл от маймуната, която Бог е създал по свой образ и подобие.
Alfa Romeo 146 ti (само с чип и филтър )
Fiat Brava JTD
In our country, there are examples where a 8v tvinspark shot up to 400 horsepower (gauge 1,7bar turbine in 2871). I have formed a dilemma) My 1.5-liter engine capable of 400 horsepower at a sufficient level of training (head porting CYLINDERS, valve replacement on enlarged) and the range of work will shift to the zone 5000-8500 rpm crankshaft.
In tvinsparka working volume of 1.8 liters, and can be done, and 2.0 liters, and even a little more. Probably the motor will be much more flexible and range in 3000-7000 will be the best for me) But 400 horsepower - a lot, a lot of difficulties will to implement all the power to the front drive car. I and the turbine - TD05h-18g with billet wheel will not give more than 380 horsepower)
For the second week thinking about tvinspark)))))))))))))))
---------- Post added at 11:20 ---------- Previous post was at 11:12 ----------
Thank You! I try!))
Hello everyone! In the past year, did reinforced axle to the VAZ (Lada) in drag. The best time for 402 meters - 11.4. External constant velocity joints of the Alfa Romeo 156 ZHTD slightly modified, internal constant velocity joints - 164 3.0. The whole season lasted axle to power about 500-550 horsepower. Gearboxes on this VAZ - Mitsubishi Evo RS
Хубаво искате да си пишете на английски, но това не е по правилата!!!
159-2.0-JTDm 136
147-Q2
Пишете на български,темата е интересна а и форума е български! Подкрепям колегата haljscho!
AR Type 939 2.4 JTDm TI Q-Tronic DPFon EX
AR Type 932 2.4 JTD hard tuned EX
Bmw E61 535d 500hp/900nm EX
AR 155 Evo 3.2 v6 Project
