Нормално ли е жинаги когато запаля мотора да се вклуцва климатроника,независимо на какво положение е
Alfa Romeo Giulia Veloce,Alfa Romeo 155 1.8 TS
Ex-Alfa Romeo156 1.8,Alfa romeo Gt 2004,2007,Alfa Romeo 155 V6,Alfa Romeo Giulietta
Spored men ne e normalno.Bi triabvalo kato kato dadesh kontakt da e na sashtoto polojenie kakto kogato si sprial.
На някой 156тица е така....Нормално си е...
И при мен е така. Обаче в един сайт прочетох начин да го спреш това нещо. Това си е чиста проба комбинация от въртене на ключа и врътките насам-натам. Виж това долу на английски, просто нямам време да го превеждам, извини ме за което:
The air con always comes on whenever starting the car, regadless of
outside temperature. This bit tells how to turn this function on or off.
Somewhere late spring 2000 (april-july) this feature
has been eliminated although it is still in the manual.
From that date you can only switch it off by pushing the button!
Reason is, that the airco would "stink" because of damp
caused by a not ventilating cooling system.
The "story" that the airco compressor takes a lot of
power is NOT 100% true. It only takes power when it
actually cools and only very, very little when it only
dry's the air which is very comfortable (no glazy windows
in fall/winter etc). And when it does "work" and you require
full power of the engine, the airco compressor is automatically
switch off for a short period.
The "trick" to leave the airco compressor "off" after starting
the engine (like I said only for models before approx april 2000):
1. Put the ignition key in "STOP" position
2. Turn temperatur knob completely to the right (= max. temp)
3. Turn the blower knob to "0" position
4. Turn air direction knob to "mid direction" position (fully to the right)
5. WITHOUT STARTING THE ENGINE, turn the ignition key to "MAR"
6. Turn the blower knob AUTO-0-AUTO-0
7. Turn the ignition key back to "STOP"
That's all.To go back to the first setting, do the same, etc. etc.
Thanks to Gert-Jan from Holland for this info!
Това го копнах от ей този сайт:
http://www.gentleman.no/156/
Дано ти свърши работа. При мен ефектът след процедурата беше, че когато външната температура е по-ниска от зададената от теб температура климатроникът "спи" когато запалиш колата. Обаче ако вънка е например 20 градуса, а ти си му задал 18 пак включва автоматично. Естествено прецедурата е възвратима - демек можеш да върнеш старото положение.
Успех
'98 Alfa Romeo 156 1,8 16V Twin Spark
Ицо,много влагодаря за информацията,имам човек който да ми го преведе
